Belkin Car Charger - Lightning connector - iPad mini/iPhone 5/iPad 4th Gen (with Retina Display)
Quicklinx: 8GJ6WS00 Mfr#: F8J075BTBLK
Car Charger 2.1 AMP For iPhone 5, iPad mini, iPad 4th gen
Small but Powerful
It's here -- the car charger designed exclusively for the iPhone 5. Get unlimited play and standby time with the low-profile design that sits flush in your dash.
Charge at the Speed of Lightning
Charge your iPhone 5, iPad mini or iPad with Retina Display (4th generation) at the fastest possible speed with the smaller, more durable Lightning connector. It's reversible, which makes plugging it in easier than ever.
Know You're Charging
Green indicator light easy to see your device is charging.
Small, Compact and Easy to Insert and Remove
Low profile design fits easily in your dash. Rubber grips allows you to insert and remove your lightning car charger with ease.
Features:
-Ultra-compact
-Plugs into any car power outlet
-2.1 Amp/10 Watts
-4' cable with reversible Lightning connector
COMPATIBILITY
iPad mini
iPhone 5
iPod nano 7th gen
iPod touch 5th gen
iPad 4th gen
  • Small but powerful
    Charge your iPhone 5 on the road with the Belkin Car Charger with lightning connector. Get unlimited play and standby time with the low-profile design that sits flush in your dash.
  • Charge at the speed of lightning
    Charge your iPhone 5, iPad mini or iPad with retina display at the fastest possible speed with the smaller, more durable lightning connector. It's reversible, which makes plugging it in easier than ever.
  • Power up your iPhone 5
    The lightning connector has a reversible design for quick and easy connections.
  • Small, compact and easy to insert and remove
    Low profile design fits easily in your dash. Rubber grips allow you to insert and remove your lightning car charger with ease.
  • Know you're charging
Belkin Car Charger car power adapter - Lightning - 10 Watt
Car power adapter
Output Connector Type
Lightning
Max Electric Current
2.1 A
Power Provided
10 Watt
Cables
iPhone / iPad charging cable - 1.2 m
Car power adapter
Tablet, mobile phone
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Output connectors
Apple Lightning
Power Provided
10 Watt
2.1 A
