Belkin BOOSTUP™ Wireless Charging Pad
Quicklinx: D2WGWS00 Mfr#: F7U014drSLV
Although the charger works wirelessly, it doesn't sacrifice speed. The charger can bring your phone's battery from zero to 100 percent just as quickly as a conventional, 5-watt wired adapter. With its 1-amp output, the charger delivers power to your phone smoothly and quickly.
You can easily slip the QI Wireless Charging Pad into a pocket or bag thanks to its compact, travel-friendly design. The charger features a small footprint and takes up a minimal amount of space on your desk. And with its elegant design and black finish, it can blend in with any home or office environment.
  • Apid, continuous charging
  • Elegant, compact design
  • Soft pad keeps your phone secure
    The charging pad of the QI Wireless Charging Pad is soft and smooth, providing your phone with a safe cushion while it is charging. The pad's high-friction material grips the phone and prevents it from slipping.
Belkin Qi Wireless Charging Pad wireless charging mat - + AC power adapter
Wireless charging mat
Image Colour Disclaimer
The displayed product image may be a different colour
Output Connector Type
Magnetic - on cable: Micro-USB
Wireless Charging
Wireless Charging Standards
Qi
Cables
Micro-USB to USB cable
Samsung Galaxy S6, S6 edge, S7
Wireless charging mat + AC power adapter
Input Connectors
5 pin Micro-USB Type B
Output connectors
Magnetic
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
1 A
Wireless Charging
Qi
AC Power Adapter Included
LED indicator, scratchproof, anti-slip base
Qi
