Optimised for Apple and Samsung devices, the Boost Up Wireless Charging Pad 10W is tuned to deliver the fastest possible wireless charging speed to Qi-enabled iPhone models at 7.5-watts, and Samsung devices at 9-watts. Just lay your phone onto the pad for a quick and easy power boost. Compatible with any Qi-enabled smartphone, the Boost Up Wireless Charging Pad 10W has been engineered to provide the fastest possible wireless charging speed to iPhone and Samsung devices, while delivering a standard 5W charge to all other Qi-enabled devices. A white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object like keys or coins. The light is specially designed to not disrupt the surrounding environment. Charge without removing your case. Boost Up Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm. The Quick Charge 3.0-compatible wall charger and cable ensure optimal charge to your wireless charger. You can also connect Quick Charge-compatible devices to the wall charger using the included cable.
Fast wireless charging made simple
Optimized to deliver fast wireless charging for iPhone and Samsung devices charge at 9W, so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost. -
Universal Qi compatibility
Power any Qi-compatible phone using this single charger. The BOOST?UP Wireless Charging Pad 10W has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5W to all other Qi-enabled devices. -
LED light indicates safe and successful charging
Foreign objects like keys and coins can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence, a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment.
- Belkin BOOST UP Wireless Charging Pad wireless charging mat - + AC power adapter - 10 Watt
- Product Type
- Wireless charging mat + AC power adapter
- 9 cm x 9 cm x 1.33 cm
- 74 g
- Black
- Fast Charge Technology
- Qualcomm Quick Charge 3.0
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 10 Watt
- Cables
- Micro-USB to USB cable - 1.2 m
- 2-year warranty
- Product Type
- Designed For
- Mobile phone
- 9 cm
- 9 cm
- 1.33 cm
- 74 g
- Enclosure Colour
- Black
- Power Provided
- 10 Watt
- Wireless Charging
- Qi
- AC Power Adapter Included
- LED indicator, FOD (Foreign Object Detection), anti-slip surface
- Included Accessories
- Wall charger
- Cables Included
- MFI, Qi
- Limited warranty - 2 years
