Designed to deliver fast wireless charging for the latest smartphones, the 15W BOOST?CHARGE Wireless Charging Pad couldn't be easier to use. Unclutter your bedroom, office, or kitchen counters by going wireless - just place your phone on the pad and start charging instantly. LED light indicators and non-slip surface keep your phone charging correctly, and a 24W Quick Charge 3.0 power supply unit is included.
Charge without removing your case. Belkin’s BOOST?CHARGE Wireless Charging Pad is engineered to work with lightweight plastic cases up to 3mm.
Power any Qi-enabled device using this single charger. The BOOST?CHARGE Wireless Charging Pad 15W has been engineered to fast charge Apple, Samsung, and Google smartphones while delivering 5W to all other Qi-enabled devices.
Constant calls and texts? No problem. The nonslip material helps to grip your iPhone, keeping it safely in place while charging.
Cut the cord with 15W of power
Designed to deliver fast wireless charging for the latest smartphones, the 15W BOOST?CHARGE Wireless Charging Pad couldn't be easier to use. Unclutter your bedroom, office, or kitchen counters by going wireless - just place your phone on the pad and start charging instantly. LED light indicators and non-slip surface keep your phone charging correctly, and a 24W Quick Charge 3.0 power supply unit is included. -
Case compatible up to 3mm
Charge without removing your case. Belkin’s BOOST?CHARGE Wireless Charging Pad is engineered to work with lightweight plastic cases up to 3mm. -
Universal QI compatibility
Power any Qi-enabled device using this single charger. The BOOST?CHARGE Wireless Charging Pad 15W has been engineered to fast charge Apple, Samsung, and Google smartphones while delivering 5W to all other Qi-enabled devices. -
LED indicates charging status
Green light confirms safe charging, amber light warns that a foreign object has been detected, red light indicates that your phone is not charging. -
Non-slip material
Constant calls and texts? No problem. The nonslip material helps to grip your iPhone, keeping it safely in place while charging. -
Included power supply
A 24W Quick Charge 3.0 power supply unit is included.
- Belkin BoostCharge wireless charging pad - + AC power adapter - 15 Watt
- Product Type
- Wireless charging pad + AC power adapter
- 1.55 cm
- Diameter
- 9.5 cm
- Black
- Fast Charge Technology
- Qualcomm Quick Charge 3.0
- Wireless Charging Standards
- Qi
- Power Provided
- 15 Watt
- Power Device Details
- AC power adapter - 24 W
- 2-year warranty
- Product Type
- Designed For
- Mobile phone
- 1.55 cm
- Diameter
- 9.5 cm
- Enclosure Colour
- Black
- Power Provided
- 15 Watt
- AC power adapter: - 24 W
- Wireless Charging
- Qi
- AC Power Adapter Included
- LED indicator, FOD (Foreign Object Detection), case compatible (plastic, up to 3 mm), non-slip surface
- Included Accessories
- Power supply
- Qi
- Limited warranty - 2 years
