Belkin Boost Up 10W Wireless Charging Stand - Black
Quicklinx: FCY9WS00 Mfr#: F7U083myBLK
Hurry, only 2 left in stock!
£36.88 ex VAT
£44.25 inc VAT
FAST WIRELESS CHARGING DESIGNED FOR EVERY DAY
Optimized to safely deliver fast wireless charging up to 10W. Engineered to charge Samsung up to 9W and Apple up to 7.5W, so you get the fastest possible wireless charge every time.
THE BELKIN DIFFERENCE
  • Pioneer in technology and innovation for over 35 years
  • 1 third party maker of wireless charging accessories
  • Sleek design and thoughtful engineering deliver a superior, long-lasting product
  • Three-year warranty provides peace of mind
SAVE TIME WITH 10W OF WIRELESS POWER
Offering up to 10-watts and optimizing for Apple and Samsung means you spend less time charging with the BOOST?UP Wireless Charging Stand.
CHARGE IN PORTRAIT AND LANDSCAPE MODE
This original and thoughtful design makes it easy to align your device for a fast wireless charge in landscape or portrait mode. From browsing the web to watching a movie, it’s easy to keep using your phone while charging.
UNIVERSAL QI COMPATIBILITY
The BOOST?UP Wireless Charging Stand has been engineered to be compatible with any Qi-enabled device. Tuned to deliver the fastest possible charging speed to Apple and Samsung devices, it charges all other Qi-enabled devices at 5W.
CASE COMPATIBLE UP TO 3MM
Charge without removing your case. Just place your phone onto the stand and keep chatting, browsing, or scrolling. Our BOOST?UP Wireless Charging Stands are engineered to work with lightweight plastic cases up to 3mm.
LED LIGHT INDICATES SAFE AND SUCCESSFUL CHARGING
Foreign objects between your phone and charger can disrupt your charge, and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence, a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment.
QUICK CHARGE 3.0 WALL CHARGER IS INCLUDED
The Quick Charge 3.0-compatible wall charger and cable ensure optimal charge to your wireless charger. You can also use the included wall charger and cable to charge Quick Charge-compatible devices from zero to 80% in just 35 minutes.
  • Save time with 10W of wireless power
  • Charge in portrait and landscape mode
    This original and thoughtful design makes it easy to align your device for a fast wireless charge in landscape or portrait mode. From browsing the web to watching a movie, it's easy to keep using your phone while charging.
  • Universal Qi compatibility
  • LED light indicates safe and successful charging
Belkin BOOST UP Wireless Charging Stand wireless charging stand - + AC power adapter
Wireless charging stand
10 cm x 10 cm x 11 cm
110 g
Wireless Charging
Wireless Charging Standards
Qi
Cables
Micro-USB to USB cable - 1.2 m
Wireless charging stand + AC power adapter
10 cm
10 cm
11 cm
110 g
Enclosure Colour
Power Provided
10 Watt
Wireless Charging
Qi
AC Power Adapter Included
LED indicator, FOD (Foreign Object Detection)
Wall charger
MFI, Qi
Brand: Belkin
Price Range Ex VAT: 0 - 50
