Product
Belkin Air Shield™ Protective Case for Chromebook
Quicklinx: D2XBWS00 Mfr#: B2A077-C00
£53.14 ex VAT
£63.76 inc VAT
The Air Shield Protective Case for Chromebook is uniquely engineered both inside and out to guard against damage from drops, bumps, and impact. An interior shock-absorbing suspension system centers and positions the device, ensuring that the rugged structural case always stays on. Tested and certified by independent laboratories for drops and backside display impact, this case meets the highest standards in the industry. It also enables complete access to your device's ports, keyboard, and entire display. A slim design makes for an easy fit in backpacks and most charging carts. When device is not in use, the case allows it to be placed on its side to free up valuable desk space.
  • Always securely protected
    The Air Shield protective case is uniquely engineered both inside and out to guard against damage from drops, bumps and impact. It also enables complete access to your device's ports, keyboard and entire display. A slim design makes for an easy fit in backpacks and most charging carts.
  • Protected inside
    This shock-absorbing suspension insulates the device, while multi-layer polycarbonate, TPU and EVA foam cushioning create layers of protection against jolts, drops and bumps.
  • Protected outside
    The Air Shield is drop- and impact-tested by independent third-party laboratories. It's dropped a total of 26 times on each corner, face and edge until it meets a military-grade standard for protection.
  • Complete access
    There's never a need to remove the Air Shield protective case. Your device's ports, switches, keyboard and screen are fully accessible when the protective case is on.
  • Universal fit
    With a universal fit for most 11-inch devices. A compact design makes it easy to slip into a backpack or messenger bag, and it also fits neatly into most charging carts.
Belkin Air Shield Protective Case for Chromebook - notebook carrying case
Notebook carrying case
Package Content
EVA foam
Product Material
Polycarbonate
32.7 cm x 25 cm x 3.4 cm
Notebook Compatibility
11"
Impact resistant, shock absorption, Thermoplastic polyurethane (TPU) liner, ports and controls access, drop protection
Product Material
Polycarbonate
Package Content
EVA foam
32.7 cm
25 cm
3.4 cm
11"
Notebook Compatibility Dimensions
30.5 cm x 22.5 cm x 2.7 cm
Closure Type
Clasp closure
Belkin Air Shield™ Protective Case for Chromebook Bundle deal on Belkin Air Shield™ Protective Case for Chromebook
£152.90
Brand: Belkin
Price Range Ex VAT: 50 - 100
