Belkin Air Protect SheerForce Case for iPhone 7/8 - Rose Gold
Quicklinx: DXT1WS00 Mfr#: F8W808btC03
Device Type: iPhone 7 / 8
Type: Case
Hurry, only 2 left in stock!
£19.11 ex VAT
£22.93 inc VAT
SheerForce Case for iPhone with Air Protect Technology provides advanced protection through a tough outer shell with a strong internal structure. Durable, lightweight and incredibly slim, it has been carefully color-matched to blend seamlessly with the look, feel and color of your iPhone. With free, unrestricted access to all iPhone ports, and highly responsive 'push+click' buttons, this strong, slim case is the perfect way to keep your iPhone lightweight, portable and above all, protected.
  • Beautifully strong
  • With Air Protect technology
    Air Protect technology hides a strong but flexible internal structure inside a slim, form-fitting case, to deliver better impact-absorption. It is also anti-scratch and UV-resistant to avoid discoloration. This is protection that stays strong and beautiful.
  • Impact + drop protection
    An internal wave design creates air pockets providing a lightweight protective layer to cushion force from drops or impacts. What's more, the sides of the case feature a micro-pattern texture, which is not only visually appealing but provides added grip, minimizing the risk of accidental drops that could damage your phone.
  • Exquisitely matched
    SheerForce is designed to be a perfect match for your iPhone in both color and feel, because if you're going to choose the best in design, why hide it in a case that's not its equal? The chrome edge has been carefully color-matched to your iPhone and vacuum-metallized to give it a premium high gloss metallic finish. Color selection may very.
  • Added extras
    Invisible from the outside, the case interior features a micro-dot pattern designed to prevent the case sticking to the back of your iPhone, which can cause the illusion that there is water inside the case.
  • All access
    Free, unrestricted access to all your iPhone's features means ports are easy to access, buttons are highly responsive with a 'push+click' feel, and all case elements are designed to keep your phone lightweight, portable and above all, protected.
  • Tested for everyday use
    All Belkin products are submitted to rigorous testing, and SheerForce phone cases are no exception. Tested to withstand the effects of drops or abrasive components ensures advanced protection and scratch-resistance for your device. Belkin cases are also tested to ensure they maintain their look and fit through exposure to extreme temperatures, high humidity, UV rays, solvents and heavy use over the lifetime of the device.
Belkin AIR PROTECT SheerForce - back cover for mobile phone
Back cover for mobile phone
Material
Thermoplastic polyurethane (TPU)
Rose gold
Apple iPhone 7
Material
Rose gold
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
UV-proof, scratch-resistant, impact protection, drop-proof
Cover Type
Back cover
Apple iPhone 7
Type: Case
Brand: Belkin
Price Range Ex VAT: 0 - 50
