Belkin Air Protect™ Always-On Case 11"
Quicklinx: D2X6WS00 Mfr#: B2A074-C00
The Belkin Air Protect Case for Chromebooks and laptops is designed for active classroom environments and safe transport inside and outside school. Work directly from this protective case without the need to remove your device, reducing potential damage.
These cases feature protective padding and reinforced stiffening that absorb impact, making the Air Protect the ideal classroom case for Chromebooks and laptops. Its durable exterior will protect your investment from tear and constant usage. Innovative universal connect technology keep your device, even in use, safely secured while providing a comfortable typing angle and full visibility of your screen. The non-slip EVA molded base elevates your device, ensuring optimum ventilation to cool operation, even after hours of constant usage.
A zippered front pocket accommodates storage for chargers and other accessories. When opening your Belkin Air Protect case, you will have direct access to charging ports and other connections on the sides of your laptop.
  • Auto wake
    This simple one-zip solution ensures your device will be safe from shifting or sliding and makes powering-up easier and more efficient, without hampering screen visibility.
  • Connectivity
    Air Protect supports full access to Wi-Fi. Side ports are accessible when the device is in use.
  • Durability
    Air Protect cases are constructed to be durable and lightweight, with multi-layer cushioning to protect mobile devices against drops and accidental mishaps.
Belkin Air Protect Case for Chromebooks and Laptops - notebook carrying case
Notebook carrying case
Product Material
Molded EVA
Notebook Compatibility
11"
Shockproof, ID card window, tear-resistant, drop-proof, zippered front pocket, sleep/wake function, airflow back paddings
Carrying Strap
Shoulder carrying strap, top carry handle
Product Material
Molded EVA
11"
Notebook Compatibility Dimensions
30 cm x 20.8 cm x 2.79 cm
Additional Compartments
Personal accessories, chargers
Carrying Strap
