Belkin Air Protect™, 14-inch Always-On Slim Case
Quicklinx: D2X9WS00 Mfr#: B2A076-C00
Device Type: Laptop
Type: Carry Case
Device Screen Size: 14"
Colour: Black
19 in stock
£32.37 ex VAT
£38.84 inc VAT
Designed specifically for business and education environments, Air Protect Always On Slim Case are the easiest, safest way to make Chromebooks and Laptops a permanent fixture. Preserving functionality through full screen visibility and access to all ports and connections when open, the sturdy exterior guards against damage through constant use, while the slim, compact design fits easily inside a backpack.
  • Auto-wake
    Simply unzip the sleeve to activate the device, allowing full access to screen and all device ports.
  • Stay put feature
    Innovative micro-gel and universal screen mount clips keep the device secured, and prevent sliding when in use. A full tilt-back design allows for multiple screen positioning angles.
  • Hard-wearing
    Sturdy exterior construction guards against rips, tears and wear from constant use. The case also features protective padding and reinforced stiffeners on all six sides, to shield the device against accidents and damage from drops.
  • Always on
    Allowing users to work directly from the case, means there's no need to need to remove the device and expose it to risk. It also ensures that the device enjoys optimum ventilation through a molded elevated base, to keep cool during hours of consistent use.
  • Perfect for on-the-go
    Easy to use and easy to transport. Take your laptop or Chromebook anywhere with an integrated carrying handle, or fit the slim, compact sleeve easily into a backpack.
Belkin Air Protect Always-On Slim Case for Chromebooks and Laptops notebook sleeve
Notebook sleeve
Notebook Compatibility
14"
Impact resistant, tear-resistant, protective padding, molded, ports and controls access
Carrying Strap
Top carry handle
Notebook sleeve
14"
Carrying Strap
Top carry handle
Belkin Air Protect™, 14-inch Always-On Slim Case Bundle deal on Belkin Air Protect™, 14-inch Always-On Slim Case
£131.54
Device Type: Laptop
Type: Carry Case
Colour: Black
Brand: Belkin
Price Range Ex VAT: 0 - 50
