Belkin Advanced Secure DVI-I KVM/Audio Switch - 4 ports - desktop
Quicklinx: C0H5WS00 Mfr#: F1DN104Bea
Belkin's Advanced Secure DVI-I KVM Switch offers superior security and data protection by providing true data path isolation between systems and networks. It is fully compatible with legacy and new government systems and exceeds NIAP security requirements. Using uni-directional data paths with optical diodes, it prevents peripherals from being used to leak information from one computer system to another. Additional security is provided through its end-to-end tamper-proof system that prevents physical tampering, and its intuitive user interface reduces user-switching errors by providing clear identification. Expect the best compatibility out-of-the-gate with a Secure KVM solution that's designed and vigorously tested to work seamlessly with common systems and peripherals used by the defense and intelligence community.
  • Dedicated processors with emulators for every port
    Isolated port paths for video, audio, peripherals, and smart card readers prevent data leaks between computers.
  • Unidirectional data paths
    Optical data diodes prevent peripherals from being used to breach systems.
  • Display security
    Protected display interface prevents data leakage via the monitor.
  • Peripheral management
    USB device detection prevents unauthorized peripheral usage.
  • Anti-tampering
    Internal electrical sensors render unit inoperable if opened.
  • Multi-platform support
    Supports cross-platform systems, including DVI-D, DVI-I, VGA video interface technologies with Belkin Smart Cables.
  • Uni-body chassis
    Minimizes entry points and prevents physical tampering.
  • Secure labeling
    Holographic tamper-evident product label provides visual indication and prevention of tampering.
  • Customizable port coloring and naming
    Facilitates port identification and reduces user switching errors.
  • Fast switching
    No keyboard or mouse delays when switching ports.
  • Easy mounting
    Uses an integrated mounting track to allow under-desk or side-wall mounting, creating extra desk space.
  • High retention connectors
    Semi-locking USB ports prevent accidental disconnection.
  • Secure packaging
    Tamper-evident packaging ensures product is not tampered with during transport.
Belkin Advanced Secure DVI-I KVM Switch - KVM / audio switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
Temperature sensor
31.8 cm x 4.3 cm x 16.3 cm
1.7 kg
Red Hat Linux, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
2560 x 1600 @ 60 Hz
Temperature sensor
Status Indicators
Port status
4 x DVI-I (dual link) , 8 x USB Type B , 2 x keyboard (PS/2) / mouse (PS/2) , 4 x audio mini-jack , 3 x USB Type A
External power adapter
FCC, EAL 2+
31.8 cm
4.3 cm
16.3 cm
1.7 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
