Product
Brand
Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Red
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B9ZXWS00 Mfr#: F8J147bt04-RED
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
Belkin Lightning cable - Lightning / USB - 1.22 m
Cable
Length
1.22 m
Connector
Lightning - male
Connector (Second End)
USB - male
90° connector
Cable Type
Lightning cable - 90° connector
Interface Supported
Lightning / USB
Length
1.22 m
Red
Connector
Apple Lightning - male
4 pin USB Type A - male
