Product
Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Purple
Quicklinx: B9ZWWS00 Mfr#: F8J147bt04-PUR
£15.92 ex VAT
£19.10 inc VAT
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
  • Compact & portable
    The longer 4-foot MIXIT Lightning to USB Cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Case compatibility
    Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin Lightning cable - Lightning / USB - 1.22 m
Cable
Length
1.22 m
Purple
Connector
Lightning - male
Connector (Second End)
USB - male
90° connector
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable - 90° connector
Interface Supported
Lightning / USB
Length
1.22 m
Purple
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s , Apple iPod nano (7G) , Apple iPod touch (5G)
Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Purple Bundle deal on Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Purple
£115.68
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Air 2
Device Type: iPad Mini
Device Type: iPod
Brand: Belkin
Price Range Ex VAT: 0 - 50
