Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Green
PRICE DROP! 50% OFF!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B9ZSWS00 Mfr#: F8J147bt04-GRN
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road. Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
  • Made for IPod/IPhone/IPad
    "Made for iPod,", "Made for iPhone," and "Made for iPad" mean that an electronic accessory has been designed to connect specifically to iPod, iPhone, or iPad, respectively, and has been certified by the developer to meet Apple performance standards.
  • Compact & portable
    The longer 4-foot MIXIT Lightning to USB Cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Case compatibility
    Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin Lightning cable - Lightning / USB - 1.22 m
Cable
Length
1.22 m
Green
Connector
Lightning - male
Connector (Second End)
USB - male
90° connector
Cable Type
Lightning cable 90° connector
Interface Supported
Lightning / USB
Length
1.22 m
Green
Connector
Apple Lightning - male
4 pin USB Type A - male
