Product
Brand
Belkin 90° Angled 2.4amp Lightning Sync charge cable for Apple - Black
Quicklinx: B9ZPWS00 Mfr#: F8J147bt04-BLK
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road. Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
Belkin Lightning cable - Lightning / USB - 1.22 m
Cable
Length
1.22 m
Connector
Lightning - male
Connector (Second End)
USB - male
90° connector
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable - 90° connector
Interface Supported
Lightning / USB
Length
1.22 m
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s , Apple iPod nano (7G) , Apple iPod touch (5G)
