Ideal for your nightstand, the BOOST UP Wireless Charging Dock provides 3-in-1 charging to power your essential devices while you sleep.
Fast wireless charging
The wireless charging pad is optimized to recharge your phone battery as fast as possible. Your phone will charge faster using this dock. -
Charge a third device
A USB-A port allows you to connect a third device to create a charging station on your nightstand. This means all your essential devices can charge simultaneously to be fully charged when you need them. -
No need to remove your case
Charge without removing your phone from its case. The BOOST UP Wireless Charging Dock is engineered to work with lightweight plastic cases.
- Belkin BOOST UP Wireless Charging Dock wireless charging stand - + AC power adapter
- Product Type
- Wireless charging stand
- 18.6 cm x 10.1 cm x 12.6 cm
- 536 g
- White
- Output Connector Type
- USB
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Device Details
- AC power adapter - 4 pin USB Type A - 5 W - 1 A , AC power adapter: 2 x - wireless charging stand - 7.5 W
- Cables
- Power cable - 1.5 m
- 3-year warranty with product registration
- Designed For
- Apple iPhone 8, 8 Plus, X, XR, XS, XS Max; Watch
- Product Type
- Wireless charging stand + AC power adapter
- 18.6 cm
- 10.1 cm
- 12.6 cm
- 536 g
- Enclosure Colour
- White
- Output connectors
- 4 pin USB Type A
- AC power adapter: 4 pin USB Type A - 5 W - 1 A , AC power adapter: 2 x wireless charging stand - 7.5 W
- Wireless Charging
- Qi
- AC Power Adapter Included
- LED indicator, FOD (Foreign Object Detection), simultaneously charges up to 3 devices, Nightstand mode support, case compatible (plastic, up to 3 mm)
- Equipment Protection Value
- 1500 British Pounds
- Cables Included
- Qi
- Limited warranty - 3 years with product registration
- Designed For
- Apple iPhone 8, 8 Plus, X, XR, XS, XS Max , Apple Watch
