Product
Brand
Belkin 4000mAh Portable Dual USB Rechargable Battery Pack - Red
Quicklinx: BB41WS00 Mfr#: F8M979btRED
The MIXIT? Power Pack 4000 lets you keep your devices charged no matter where you are. This versatile charging device has two USB ports so you can charge tablets, e-readers, and other USB-enabled devices even when you don't have access to a power outlet or a computer. Simply charge the battery pack before leaving your house and connect it to your device using your USB cable whenever you need a charge.
The MIXIT? Power Pack 4000 ensures that you'll always have an extra charge within reach. And it has two USB ports, which means you can charge a friend's smartphone at the same time that you charge yours. With its compact and lightweight design, it's ideal for travel and easily slips into any handbag or backpack.
With the MIXIT? Power Pack 4000, you'll always have a reliable backup if you run out of charging options. The battery pack is rated for 4,000 mAh and remains charged for days after you last plugged it in. Use it to provide your phone with a quick boost for those times when you need to make a call or text.
Belkin MIXIT Power Pack 4000 - power bank
Power bank
Output Connector Type
USB - on cable: Micro-USB
4000 mAh
Cables
Micro-USB to USB cable - 15.2 cm
Power bank
Enclosure Colour
Red
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
4000 mAh
BB41 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.08
BB41 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.39
BB41 C2G 2-Port USB 2.0 Manual Switch In Stock £17.49
BB41 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.21
BB41 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BB41 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.46
BB41 C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.39
