The MIXIT Power Pack 4000 lets you keep your devices charged no matter where you are. This versatile charging device has two USB ports so you can charge tablets, e-readers, and other USB-enabled devices even when you don't have access to a power outlet or a computer. Simply charge the battery pack before leaving your house and connect it to your device using your USB cable whenever you need a charge.
Charge two devices at once
The MIXIT Power Pack 4000 ensures that you'll always have an extra charge within reach. And it has two USB ports, which means you can charge a friend's smartphone at the same time that you charge yours. With its compact and lightweight design, it's ideal for travel and easily slips into any handbag or backpack. -
Retains charge for days
With the MIXIT Power Pack 4000, you'll always have a reliable backup if you run out of charging options. The battery pack is rated for 4,000 mAh and remains charged for days after you last plugged it in. Use it to provide your phone with a quick boost for those times when you need to make a call or text. -
Broad compatibility
The MIXIT Power Pack 4000 is compatible with any device that charges via a USB cable, including most tablets, smartphones, and additional devices that charge with a USB cable.
- Belkin MIXIT Power Pack 4000 power bank - USB
- Product Type
- Power bank
- Green
- Output Connector Type
- Total 2: USB
- Max Electric Current
- 2.4 A
- Battery
- 4000 mAh
- Cables
- USB charge cable - 15.2 cm
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- Enclosure Colour
- Green
- Output connectors
- Total 2: 4 pin USB Type A
- 2.4 A
- Capacity
- 4000 mAh
- Charging status indicator
- Cables Included
