Belkin 4.8Amp Dual USB-A Home Charger UK Plug
Quicklinx: FCYGWS00 Mfr#: F7U049mySLV
More than 50 in stock
£23.01 ex VAT
£27.61 inc VAT
The days of charging triage are over. With the Boost Charge 2-Port Home Charger two universal USB-A ports are compatible with smartphones, tablets, power banks and more. Each port has a total of 12W, totally 24W in this compact home charger.
  • Charge two devices simultaneously
  • A quick power boost
    Each port has a dedicated 12W, so there's no power slow down when you charge more than one device. Spend less time connected to the outlets and more time doing the things you love.
  • Universal USB-A compatibility has you covered
    Both USB-A ports work with all your USB-A devices, just connect any USB-A cable. Power smartphones, tablets, cameras, power banks, Bluetooth speakers, smart watches and more with a single home charger.
Belkin BOOST CHARGE 2-Port Home Charger power adapter
Power adapter
3.2 cm x 5 cm x 5.8 cm
Silver
Output Connector Type
USB
Power adapter
3.2 cm
5 cm
5.8 cm
Enclosure Colour
Silver
Input Connectors
Power BS 1363A
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 Watt
Max Electric Current
4.8 A
Equipment Protection Value
1500 British Pounds
Brand: Belkin
Price Range Ex VAT: 0 - 50
