Your basket is empty
Belkin 3m Purple Lightning-USB Charge and Sync Cable
Quicklinx: BB2HWS00 Mfr#: F8J023bt3M-PUR
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Belkin MIXIT Lightning to USB ChargeSync - Lightning cable - Lightning / USB 2.0 - 3 m
Cable
Length
3 m
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB 2.0
Length
3 m
Sync and charge
Purple
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
