ON-THE-GO CHARGING FOR MOBILE DEVICES
The Belkin 2 Way Travel Surge with 2 x 2.4amp USB Charging is the ideal travel companion--just toss it in your suitcase to charge your mobile devices wherever you go. Plug this mini surge protector into any wall outlet and power up to two AC devices at once.
In addition to the two AC outlets, there are two USB ports (2.4A combined) that offer convenient one-source charging for your tablet and mobile devices.
- 2 AC Outlet Travel Surge Protector
- 306 Joules of Surge Protectio
- $25k Connected Equipment Warranty
- Dual Port 2.4A Universal USB Charging (Shared)
- Small Form Factor for Use at Home & On-The-Go
- Belkin Travel - surge protector
- Surge protector - external
- Output connectors
- 2 x power BS 1363 , 2 x 4 pin USB Type A
- Power Output Connectors Details
- Surge Energy Rating
- 306 Joules
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.02 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.24 |
C2G 2-Port USB 2.0 Manual Switch | In Stock | £16.25 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £11.34 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £25.75 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £14.89 |
C2G USB 2.0 To Fast Ethernet Adapter | In Stock | £18.94 |
