Belkin 2.4 Amp Charger with 1.2m Micro USB Cable - White
Quicklinx: FCX0WS00 Mfr#: F8M886dr04-WHT
Never suffer from the dreaded low battery again. Belkin Universal mobile chargers are able to charge the greatest number of devices on the market, making them the only chargers you'll ever need. The sleek, compact design is easy on the eyes and you can plug it in virtually anywhere, so a battery boost is always in reach.
  • Removable cable included
    The Belkin Universal Home Charger comes with a 1.2-meter Micro-USB to USB cable for charging your tablet or smartphone. And because it's removable, the cable can be used anywhere; plug it into your laptop to charge and sync, or into a car charger for power on the go. The cord is compatible with most tablets and smartphones with a Micro-USB port, making it versatile and easy to use with other chargers or equipment.
  • Compatible with the most mobile devices
    This charger's USB 2.0 Port is universal, so you can plug in any USB charging cable to power a variety of different mobile devices, including any brand smartphone, any brand tablet and more. Just swap out the included cable for a USB cable that corresponds with the device you want to charge (additional USB cables sold separately).
  • Sleek design, easy to use
    The Belkin Universal Home Charger is fast, small and designed to fit seamlessly with home décor. Plug it into any wall and it blends in without blocking your other outlets.
  • Share one charger
    Because it's so versatile, the Belkin Universal Home Charger is ideal for a family with different devices. Empty your drawers of old chargers, and take the guess work out of pairing cables to ports. When you need to switch between multiple devices, simply swap out the cable.
  • Fastest charging available
    Belkin Universal Home Charger always delivers the maximum amount of power your device can charge with-up to 2.4 amps. Your device will charge up to 40% faster than a standard 5W charger and get you on your way sooner.
Belkin Universal Home Charger power adapter - USB - 12 Watt
Power adapter
White
Output Connector Type
USB - on cable: Micro-USB
Max Electric Current
2.4 A
Power Provided
12 Watt
Cables
Micro-USB to USB cable - 1.2 m
Power adapter
Camera, portable player, tablet, mobile phone
Enclosure Colour
White
Input Connectors Qty
1
Output connectors
4 pin USB Type A
Power Provided
12 Watt
Detachable Cable Connector Type
Micro-USB Type B
2.4 A
Equipment Protection Value
1500 British Pounds
