Belkin 18W USB-C Home Charger (UK Plug) - White
Quicklinx: FCWXWS00 Mfr#: F7U096myWHT
33 in stock
£11.92 ex VAT
£14.30 inc VAT
This compact 18-watt wall charger with USB-Power Delivery means fast charging for your USB-PD-enabled devices. Supports Fast Charge for iPhone to charge iPhone 8 or later from zero to 50% in 30 minutes with the included cable, and other smartphones/ tablets at optimal speeds.* Purposefully designed to be travel-friendly, this pocket-sized charger easily fits to any environment at home or when you're out and about. A connected equipment warranty protects your devices for added peace of mind.
Measuring in at 55 x 42 mm across, with a depth of just 23 mm, this compact charger sits flat to the wall to fit easily behind furniture or in hard-to-reach outlets. It's also perfectly-sized to fit in a pocket or bag, which means you'll have access to fast charging wherever you're headed.
  • Fast charge with USB power delivery
    This compact 18-watt wall charger with USB-Power Delivery means fast charging for your USB-PD-enabled devices. Supports Fast Charge for iPhone to charge iPhone 8 or later from zero to 50% in 30 minutes with the included cable, and other smartphones/ tablets at optimal speeds. Purposefully designed to be travel-friendly, this pocket-sized charger easily fits to any environment at home or when you're out and about.
  • Seriously small
  • Works in any space
    The adjustable plug design allows you to avoid blocking other outlets and repositions the USB-C port for convenient placement of the connected cable - particularly useful when using in a power strip or surge protector with multiple-outlets.
  • Included MFi-certified cable
    The 4ft. /1.2m USB-C to Lightning Cable is included so you can fast charge your iPhone straight out of the box. The cable is also MFi-certified to guarantee compatibility with iOS devices, and meets the high quality standards set by Apple.
Belkin BOOST CHARGE Wall Charger power adapter
Power adapter
4.15 cm x 5.42 cm x 2.3 cm
White
Output Connector Type
USB-C
Power adapter
4.15 cm
5.42 cm
2.3 cm
Enclosure Colour
White
Output connectors
24 pin USB-C
Power Provided
18 Watt
Adjustable position plug, PowerDelivery Technology
Equipment Protection Value
2500 US Dollars
USB-IF, MFI
Brand: Belkin
Price Range Ex VAT: 0 - 50
