Fit for your life, Beats X earphones are the perfect wireless companion. Experience authentic, clear sound throughout your day with a long battery life. Their unique flex-form cable provides all-day comfort and easy pocket portability.
Driven by the Apple W1 chip
Incorporating the efficient Apple W1 chip brings seamless setup and switching for your Apple devices, up to 8 hours of battery life, and Fast Fuel technology for 2 hours of play with a 5-minute charge. -
Wireless the way it should be
BeatsX works as hard as you do. Sleek, light, and compact, these earphones are your perfect wireless companion. They instantly set up - just power on and hold near your iPhone - then simultaneously connect to your Apple Watch, iPad, and Mac. -
Stay connected, stay in the zone
RemoteTalk allows you to take calls with a built-in mic, play music, adjust volume, and activate Siri. The Apple W1 chip features Class 1 Bluetooth connectivity - the advanced classification for range and signal strength. With excellent performance, BeatsX seamlessly syncs to your devices, so you can easily move about, keep the music going, and stay productive throughout your day. -
Sound that stays with you
BeatsX features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for the most natural tonality across a broad range of genres. -
Fit for your life
Whether playing in your ears or hanging around your neck, BeatsX is incredibly sleek and comfortable for all-day wear. The unique Flex-Form cable provides a flexible fit, while a variety of eartip options offer personalized comfort. And when you're not wearing your earphones, magnetic earbuds keep them tangle-free, and they easily coil up for compact portability.
- Beats X - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Blue
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Noise Isolating
- Microphone
- On-cable
- Microphone Operation Mode
- Mono
- Controls
- Volume, answer/end
- 1-year warranty
- Designed For
- TV 4K, HD
- Product Type
- Compatibility
- Blue
- Recommended Use
Audio Output
- In-ear
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Noise Isolating
- In-Cord Volume Control
Microphone
- On-cable
- Mono
Remote Control
- Controls
- Included Accessories
- Carrying case, 4 ear tips, removable secure fit wingtips
- Cable Details
- USB charge cable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 8 hour(s)
- Limited warranty - 1 year
- Designed For
- Apple TV 4K, HD
