Beats X Earphones - Black
Quicklinx: DTMJWS00 Mfr#: MTH52ZM/A
Accessory Type: Earphones
Connectivity: Wireless
Colour: Black
Stock Status: In Stock, Used Stock
More than 50 in stock
£66.66 ex VAT
£79.99 inc VAT
Express delivery Order within the next 21 hours for delivery on Wednesday
Fit for your life, Beats X earphones are the perfect wireless companion. Experience authentic, clear sound throughout your day with a long battery life. Their unique flex-form cable provides all-day comfort and easy pocket portability.
  • Driven by the Apple W1 chip
    Incorporating the efficient Apple W1 chip brings seamless setup and switching for your Apple devices, up to 8 hours of battery life and Fast Fuel technology for 2 hours of play with a 5-minute charge.
  • Wireless the way it should be
    BeatsX works as hard as you do. Sleek, light and compact, these earphones are your perfect wireless companion. They instantly set up — just power on and hold near your iPhone — then simultaneously connect to your Apple Watch, iPad and Mac.
  • Stay connected, stay in the zone
    RemoteTalk allows you to take calls with a built-in mic, play music, adjust volume and activate Siri. The Apple W1 chip features Class 1 Bluetooth connectivity — the advanced classification for range and signal strength. With excellent performance, BeatsX seamlessly syncs to your devices, so you can easily move about, keep the music going and stay productive throughout your day.
  • Sound that stays with you
    BeatsX features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for the most natural tonality across a broad range of genres.
  • Fit for your life
    Whether playing in your ears or hanging around your neck, BeatsX is incredibly sleek and comfortable for all-day wear. The unique Flex-Form cable provides a flexible fit, while a variety of eartip options offer personalized comfort. And when you’re not wearing your earphones, magnetic earbuds keep them tangle-free, and they easily coil up for compact portability.
Beats X - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Noise isolating
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end
10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod touch; TV; Watch
Compatibility
Recommended Use
Headphones
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Controls
Volume, answer/end
USB charge cable
4 ear tips, removable secure fit wingtips
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
8 hour(s)
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max , Apple iPod touch , Apple TV , Apple Watch
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DTMJ 040940
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £35.73
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Colour: Black
Brand: Beats
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
