urBeats3 wired earphones feature fine-tuned acoustic design via an axial-aligned driver to deliver an exceptional listening experience. This means that no matter what music you're playing you'll get optimized sound output. Laser precision venting provides micro-pressure balanced bass, while dual-chamber acoustics deliver synchronized sound and natural tonality across all types of music.
Designed for your life, urBeats3 wired earphones feature an optimal ergonomic fit that combines sleek style with iconic Beats sound for all-day wear. A variety of ear tip options provide individualized fit for noise isolation while optional secure-fit wingtips provide confidence and added stability during activity.
Wherever your day takes you, you can stay connected with RemoteTalk. Take calls with a built-in mic, control your music, and even activate Siri all with the push of a button. And when you're not wearing them, the tangle-free flat cable and magnetic ear buds easily coil up in a carrying case for compact portability.
Elevate your music
urBeats3 wired earphones feature fine-tuned acoustic design via an axial-aligned driver to deliver an exceptional listening experience. This means that no matter what music you're playing you'll get optimized sound output. Laser precision venting provides micro-pressure balanced bass, while dual-chamber acoustics deliver synchronized sound and natural tonality across all types of music. -
Made to fit you
Designed for your life, urBeats3 wired earphones feature an optimal ergonomic fit that combines sleek style with iconic Beats sound for all-day wear. A variety of ear tip options provide individualized fit for noise isolation while optional secure-fit wingtips provide confidence and added stability during activity. -
Stay on the go
- Beats urBeats3 - earphones with mic
- Product Type
- Earphones - wired - 3.5 mm jack
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
- Noise isolating
- Microphone
- On-cable
- Controls
- Answer/end, play/pause, next/previous track
- Designed For
- 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad (3rd generation); iPad 1; 2; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod nano (5G, 6G, 7G); iPod touch
- Product Type
- Earphones - 3.5 mm jack
- Compatibility
- Black
- Recommended Use
Headphones
- In-ear
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
- In-Cord Volume Control
- Magnetic ear buds
Microphone
- On-cable
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone 3.5 mm 4-pole)
- Cables Included
- Headphones cable - anti tangle
- Included Accessories
- Carrying pouch, 4 pairs of ear tips, removable secure fit wingtips
- Designed For
- Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod nano (5G, 6G, 7G) , Apple iPod touch (3G, 4G, 5G, 6G)
