Beats Studio3 Wireless Over-Ear Headphones - Blue
Quicklinx: DCDHWS00 Mfr#: MQCY2ZM/A
Beats Studio3 Wireless headphones deliver a premium listening experience. They actively block external noise, and the real-time audio calibration preserves clarity, range and emotion.
  • Stay connected
    Take calls, skip songs, and control your volume using the convenient multi-function on-ear controls. Bluetooth connectivity seamlessly sync your devices, so you can easily move about, keep the music going and stay productive all day.
  • Designed to fit you
    The Beats Studio3 Wireless headphone is designed for long-term comfort to match its impressive battery life. The soft over-ear cushions feature advanced venting and signature ergonomic pivoting for a custom, flexible fit for any head shape. The holistic design is lightweight, durable and comfortable, so you can get lost in your music.
Beats Studio3 Wireless - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
Blue
Headphones Form Factor
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Active Noise Canceling
Noise Isolating
Noise isolating
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track, voice assistant
10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X; iPod touch (5G, 6G); Watch
Compatibility
iPhone, iPad, iPod
Dimensions & Weight Details
18.4 cm / 260 g
Blue
Recommended Use
Headphones
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Active Noise Cancelling Technology
Pure Adaptive Noise Cancelling
In-Cord Volume Control
Detachable microphone, Apple W1 chip, Fast Fuel technology
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Detachable Cable
Carrying case
Cable Details
Micro-USB charge cable , RemoteTalk cable - detachable
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
22 hour(s)
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X , Apple iPod touch (5G, 6G) , Apple Watch
