Beats Studio Over-Ear Headphones - Blue
Quicklinx: B734WS00 Mfr#: MH992B/A
Completely redesigned, the Beats Studio over-ear headphones are even lighter, stronger, and more comfortable, and more precise than the original world-famous design. They deliver powerful, re-engineered sound alone with Adaptive Noise Canceling, a 20-hour rechargeable battery, and Remote Talk controls.
  • Feel your music
    The Beats Acoustic Engine gives you an intimate, real encounter with your music. Thanks to Beats' signature DSP software delivers the exact emotional experience that Dr. Dre, Jimmy Iovine, and some of the music industry's greatest rock, hip-hop, pop, electronic, and R&B producers want you to feel.
  • Put the world on mute
    Silence the noise from your daily commute or the drama from your loud neighbors with Beats' no-compromise dual-mode Adaptive Noise Canceling (ANC). When you're listening to music, ANC automatically strikes a balance between your audio and the world outside. And if you want to use the headphone just to cancel external noise, ANC-only mode automatically increases the level of noise cancellation to make things even quieter.
  • What batteries
    A 20-hour rechargeable battery makes sure your vibe keeps going. To prevent wasting energy, the auto on/off feature turns off when you unplug, and the visible Battery Fuel Gauge lets you see at a glance how much juice is available. Plus, you can charge the Studio via standard micro USB adapter almost anywhere.
  • Lighter, stronger, and more comfortable
    When Beats re-imagined these legendary headphones, they designed it like a beautiful sports car and made disciplined choices. They streamlined the Beats Studio with fast curves, smooth surfaces, and no visible screws. It now weighs 13 percent less than the original and has a lighter, stronger, and more comfortable headband. The ear cups are softer and there's an ergonomic bellow to create a flexible, custom fit for every head shape, so you can keep your music all to yourself.
Beats Studio - headphones with mic
Headphones - wired - 3.5 mm jack
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
English / United Kingdom
Blue
Headphones Form Factor
Full size
Foldable
Wired
Sound Output Mode
Stereo
Active Noise Canceling
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track
Compatibility
iPhone, iPad, iPod
20.3 cm
260 g
Blue
Recommended Use
Audio Output
Full size
Foldable
Wired
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Adaptive Noise Cancelling
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Detachable Cable
Hard case
Cable Details
Audio cable , USB charge cable , Microphone cable
Power adapter - external
Headphone battery rechargeable
Run Time (Up To)
20 hour(s)
