Completely redesigned, the Beats Studio over-ear headphones are even lighter, stronger, and more comfortable, and more precise than the original world-famous design. They deliver powerful, re-engineered sound alone with Adaptive Noise Canceling, a 20-hour rechargeable battery, and Remote Talk controls.
Feel your music
The Beats Acoustic Engine gives you an intimate, real encounter with your music. Thanks to Beats' signature DSP software delivers the exact emotional experience that Dr. Dre, Jimmy Iovine, and some of the music industry's greatest rock, hip-hop, pop, electronic, and R&B producers want you to feel. -
Put the world on mute
Silence the noise from your daily commute or the drama from your loud neighbors with Beats' no-compromise dual-mode Adaptive Noise Canceling (ANC). When you're listening to music, ANC automatically strikes a balance between your audio and the world outside. And if you want to use the headphone just to cancel external noise, ANC-only mode automatically increases the level of noise cancellation to make things even quieter. -
What batteries
A 20-hour rechargeable battery makes sure your vibe keeps going. To prevent wasting energy, the auto on/off feature turns off when you unplug, and the visible Battery Fuel Gauge lets you see at a glance how much juice is available. Plus, you can charge the Studio via standard micro USB adapter almost anywhere. -
Lighter, stronger, and more comfortable
When Beats re-imagined these legendary headphones, they designed it like a beautiful sports car and made disciplined choices. They streamlined the Beats Studio with fast curves, smooth surfaces, and no visible screws. It now weighs 13 percent less than the original and has a lighter, stronger, and more comfortable headband. The ear cups are softer and there's an ergonomic bellow to create a flexible, custom fit for every head shape, so you can keep your music all to yourself.
- Beats Studio - headphones with mic
- Product Type
- Headphones - wired - 3.5 mm jack
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Localisation
- English / United Kingdom
- Blue
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone
- On-cable
- Controls
- Volume, answer/end, play/pause, next/previous track
- Product Type
- Compatibility
- 20.3 cm
- 260 g
- Blue
- Recommended Use
- Localisation
Audio Output
- Full size
- Foldable
- Wired
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Adaptive Noise Cancelling
Microphone
- On-cable
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
- Detachable Cable
- Included Accessories
- Hard case
- Cable Details
- Audio cable , USB charge cable , Microphone cable
- Power Device
- Power adapter - external
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 20 hour(s)
