Beats Solo2 Wireless Headphones - Red
Quicklinx: B720WS00 Mfr#: MHNJ2ZM/A
Beats Solo2 headphones offer improved acoustics, a wider range of sound, and enhanced clarity for all the music on your iPhone, iPad, or iPod. They also deliver even greater comfort thanks to a streamlined, lightweight, and durable design.
  • Feel a new kind of sound
    The Solo2 headphones have a more dynamic and wider range of sound, with a clarity that can bring you closer to what the artist intended you to hear. You'll feel the higher fidelity audio no matter what type of music you play.
  • Custom comfort
    Starting at the center of the flexible headband, the frame is curved even more to enhance the custom-fit feeling. The earcups are ergonomically angled to complete this natural fit, and they pivot for optimal comfort and sound delivery. The earcups' premium material also helps dissipate heat and minimize sound leakage.
  • Streamlined design
    Fast-flowing curves, a lack of visible screws, and easy foldability exemplify the sleek aesthetic of Beats Solo2. That thoughtful approach extends to engineering and material selection, which together resulted in a more durable headphone that stands up to extended use.
  • No need to reach for your iOS device
    With the color-matched RemoteTalk cable, you can change songs, adjust the volume, and even take calls without having to reach for your iPhone, iPad, or iPod.
Beats Solo2 - headphones with mic
Headphones - Bluetooth - wireless
Red
Headphones Form Factor
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Controls
Volume
1-year warranty
19.8 cm
215 g
Red
Max Operating Distance
10 m
Audio Output
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Remote Control
Controls
Volume
Wireless Link
Transmission Range
10 m
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Carrying case
Cable Details
Headphones cable - 1.361 m , USB charge cable
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
12 hour(s)
Limited warranty - 1 year
