Beats Solo2 Wireless Headphones - Gloss Black
Quicklinx: CCKGWS00 Mfr#: MP1F2ZM/A
Beats Solo2 headphones offer improved acoustics, a wider range of sound, and enhanced clarity for all the music on your iPhone, iPad, or iPod. They also deliver even greater comfort thanks to a streamlined, lightweight, and durable design.
  • Feel your music
    The Beats Acoustic Engine makes your listening experience personal and real. The signature DSP software is designed to generate the emotional experience that some of the music industry's greatest rock, hip-hop, pop, electronic, and R&B producers want you to feel. This is how music would sound if the artist could play it back for you in person.
  • Put the world on mute
    Silence the noise from your daily commute or the drama from your loud neighbors with dual-mode Adaptive Noise Canceling. When you're listening to music, ANC automatically strikes the perfect blend between your music and the world outside. If you only want to use the headphone to cancel external noise, the ANC only mode automatically increases the level of noise cancelation, to put the world on mute.
  • Built-in rechargeable battery
    Dead batteries can kill your vibe. The Beats Studio Wireless comes with a built-in rechargeable battery that lasts 12 hours when using wirelessly and 20 hours when you do decide to plug in. To prevent wasting energy, the Auto On/Off feature turns the headphone off when you unplug from a wired connection and with the Battery Fuel Gauge, you always know how much juice is left. Forget specialized adapters; the Studio Wireless can be charged via micro USB almost anywhere.
  • Lighter, stronger, and more comfortable
    When Beats Studio reimagined the iconic Studio, Beats Studio designed it like a beautiful sports car and made disciplined choices. It is streamlined with fast curves, smooth surfaces, and no visible screws. Beats Studio reduced the original weight and gave it a lighter, stronger, and more comfortable headband. The softer ear cups have an ergonomic bellow that creates a flexible custom fit, so you can keep your music all to yourself.
Beats Studio Wireless - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
Gloss black
Headphones Form Factor
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track
Compatibility
iPhone, iPad, iPod
Gloss black
Recommended Use
Max Operating Distance
9 m
Audio Output
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Adaptive Noise Cancelling
Frequency Response
20 - 20000 Hz
Microphone
On-cable
Remote Control
Controls
Wireless Link
Transmission Range
9 m
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Detachable Cable
Hard case, cleaning cloth
Cable Details
Headphones cable , USB charge cable
Headphone battery rechargeable
Run Time (Up To)
20 hour(s)
