Beats Solo2 headphones offer improved acoustics, a wider range of sound, and enhanced clarity for all the music on your iPhone, iPad, or iPod. They also deliver even greater comfort thanks to a streamlined, lightweight, and durable design.
Feel a new kind of sound
The Solo2 headphones have a more dynamic and wider range of sound, with a clarity that can bring you closer to what the artist intended you to hear. You'll feel the higher fidelity audio no matter what type of music you play. -
Custom comfort
Starting at the center of the flexible headband, the frame is curved even more to enhance the custom-fit feeling. The earcups are ergonomically angled to complete this natural fit, and they pivot for optimal comfort and sound delivery. The earcups' premium material also helps dissipate heat and minimize sound leakage. -
Streamlined design
Fast-flowing curves, a lack of visible screws, and easy foldability exemplify the sleek aesthetic of Beats Solo2. That thoughtful approach extends to engineering and material selection, which together resulted in a more durable headphone that stands up to extended use. -
No need to reach for your iOS device
With the color-matched RemoteTalk cable, you can change songs, adjust the volume, and even take calls without having to reach for your iPhone, iPad, or iPod.
- Beats Solo2 - Royal Edition - headphones with mic
- Product Type
- Headphones - wired - 3.5 mm jack
- Stone grey
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
- Microphone
- On-cable
- Controls
- Volume
- 1-year warranty
- Product Type
- 19.8 cm
- 205 g
- Stone grey
Audio Output
- On-ear
- Foldable
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
Microphone
- On-cable
Remote Control
- Controls
- Volume
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Carrying case
- Cable Details
- Headphones cable - 1.361 m
- Limited warranty - 1 year
