Your basket is empty
Beats Powerbeats 2 Wireless - Blue
Quicklinx: B70ZWS00 Mfr#: MHBV2ZM/A
The Beats by Dr. Dre Powerbeats2 Wireless headphones are exceptionally light and deliver the power of dual-driver acoustics to propel you through rigorous workouts. The IPX-4 sweat- and water-resistance rating means Powerbeats2 Wireless are tough from ear bud to the tangle-free cable wrap around. There's also over-molding on the RemoteTalk for a non-slip grip when you're changing volume, switching tracks, and making hands-free calls.
Beats Powerbeats2 Wireless - earphones with mic
Earphones - Bluetooth - wireless
Recommended Use
Portable electronics
Cobalt blue
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, play/pause button, answer/end, play/pause, next/previous track
12.9-inch iPad Pro; 9.7-inch iPad Pro; iPad (3rd generation); iPad 1; 2; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display; iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod (4G, 5G); iPod classic; iPod mini; iPod nano; iPod shuffle; iPod touch
4.37 cm
24 g
Cobalt blue
Recommended Use
Protection
Waterproof
Max Operating Distance
9.1 m
Headphones
Wireless
Wireless Technology
Bluetooth
Available Microphone
Sound Output Mode
Stereo
Microphone
On-cable
Mono
Remote Control
Remote control
Supported Devices
Apple iPhone, Apple iPad, Apple iPod
Controls
Wireless Link
Transmission Range
9.1 m
Micro-USB cable
Hard case, 4 pairs of ear tips, cable clip
IPX4
Headphone battery rechargeable
Run Time (Up To)
6 hour(s)
Apple 12.9-inch iPad Pro , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G, 7G) , Apple iPod shuffle (1G, 2G, 3G, 4G) , Apple iPod touch (1G, 2G, 3G, 4G, 5G, 6G)
