Beats Powerbeats 2 Earphones with Mic - White
Quicklinx: BL63WS00 Mfr#: MHAA2ZM/A
Inspired by LeBron James, Beats Powerbeats2 headphones allow you to train relentlessly and take your workout to the next level. Completely redesigned, Powerbeats2 combines power and strength with IPX4 sweat and water resistance. Adjustable earhooks create a snug fit, letting the emotion of the music on your iPhone, iPad, or iPod power your training.
  • Powered with durability
    The metal front face provides rugged protection and its IPX4 sweat and water resistance keeps your earphones safe during your training. The over-molded RemoteTalk control allows for an easy grip while taking calls and changing tracks. Now you can make your workout even more intense without interrupting your music.
  • Fit and comfort
    To handle even the longest workout, Powerbeats2 offers adjustable earhooks with multiple fitting eartips for a comfortable and snug fit.
  • The power of sound
    Add power to your sound. Dual-driver acoustics power music through each ear bud, delivering the Beats signature sound to keep you inspired during your workout.
Beats Powerbeats2 - earphones with mic
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
White
Headphones Form Factor
In-ear - over-the-ear mount
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Controls
Volume
26.7 g
White
Recommended Use
Protection
Waterproof
Audio Output
Wired
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Remote Control
Controls
Volume
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Hard case, 4 pairs of ear tips, cable clip
Cable Details
Headphones cable - 1.19 m
IPX4
