Your basket is empty
Beats Powerbeats 2 Earphones with Mic - White
Quicklinx: BL63WS00 Mfr#: MHAA2ZM/A
Inspired by LeBron James, Beats Powerbeats2 headphones allow you to train relentlessly and take your workout to the next level. Completely redesigned, Powerbeats2 combines power and strength with IPX4 sweat and water resistance. Adjustable earhooks create a snug fit, letting the emotion of the music on your iPhone, iPad, or iPod power your training.
Beats Powerbeats2 - earphones with mic
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
White
Headphones Form Factor
In-ear - over-the-ear mount
Sound Output Mode
Stereo
Noise Isolating
Noise isolating
Microphone
On-cable
Controls
Volume
12.9-inch iPad Pro; 9.7-inch iPad Pro; iPad (3rd generation); iPad 1; 2; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display; iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod (4G, 5G); iPod classic; iPod mini; iPod nano; iPod shuffle; iPod touch
Earphones - 3.5 mm jack
26.7 g
White
Recommended Use
Protection
Waterproof
Headphones
Wired
Available Microphone
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Remote Control
Controls
Volume
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Headphones cable - 1.19 m
Hard case, 4 pairs of ear tips, cable clip
IPX4
Apple 12.9-inch iPad Pro , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G, 7G) , Apple iPod shuffle (1G, 2G, 3G, 4G) , Apple iPod touch (1G, 2G, 3G, 4G, 5G, 6G)
