Inspired by LeBron James, Beats Powerbeats2 headphones allow you to train relentlessly and take your workout to the next level. Completely redesigned, Powerbeats2 combines power and strength with IPX4 sweat and water resistance. Adjustable earhooks create a snug fit, letting the emotion of the music on your iPhone, iPad, or iPod power your training.
Powered with durability
The metal front face provides rugged protection and its IPX4 sweat and water resistance keeps your earphones safe during your training. The over-molded RemoteTalk control allows for an easy grip while taking calls and changing tracks. Now you can make your workout even more intense without interrupting your music. -
Fit and comfort
To handle even the longest workout, Powerbeats2 offers adjustable earhooks with multiple fitting eartips for a comfortable and snug fit. -
The power of sound
Add power to your sound. Dual-driver acoustics power music through each ear bud, delivering the Beats signature sound to keep you inspired during your workout.
- Beats Powerbeats2 - earphones with mic
- Product Type
- Earphones - wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- Blue
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
- Microphone
- On-cable
- Controls
- Volume
- Product Type
- 26.7 g
- Blue
- Recommended Use
- Protection
- Waterproof
Audio Output
- Wired
- Sound Output Mode
- Stereo
- Noise Isolating
Microphone
- On-cable
Remote Control
- Controls
- Volume
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Hard case, 4 pairs of ear tips, cable clip
- Cable Details
- Headphones cable - 1.19 m
- IPX4
