Beats Pill 2.0 Speaker - Black
Quicklinx: B73CWS00 Mfr#: MH812B/A
Colours:
TAP. PAIR. PLAY.
Pairing is easy. Just tap your phone to your Beats Pill and create an instant connection. Sync two Beats Pills by tapping them together to play the same song. You can also tap the Beats Pills together twice to stereo your music, making one Beats Pill the left output and the other the right.
SMALL SIZE, BIG SOUND.
Despite its compact size, the Beats Pill produces powerful sound. It’s easy to enjoy soaring highs and deep, booming bass in every room of the house.
CHANGE TRACKS FROM YOUR PHONE
Pair the Beats Pill to your phone, laptop or any other Bluetooth-enabled device to change tracks and adjust the volume from up to 30 feet away.
TOTALLY PORTABLE
The Beats Pill frees you to roam so you'll always have premium sound, anywhere you go. It’s lightweight and small enough to fit in your bag. If your phone or external device is low on battery power, you can use the Beats Pill to give it some juice.
BLUETOOTH CONFERENCING
Take that call. The Beats Pill’s Bluetooth capability and internal microphone make talking on the phone easier and better sounding than ever before.
UNBOXED
Beats Pill™ Portable Stereo Speaker with Bluetooth 1.5 m audio cable (3.5mm to 3.5 mm) USB 2.0 charge/data cable Carry case AC Power Adapter
Weight (kg): 0.31 Height (mm): 45.72 Length (mm): 190.50
  • Totally portable
    The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you’re carrying out the door. So you’ll always have high-quality sound wherever you are.
  • Tap to amplify
    Two is louder than one. Sync two Pills by tapping them together to play the same song.
  • Tap to stereo
    The new surround sound. Just tap two Pills together twice to make one Pill the left output and the other the right.
  • Rechargeable battery
    One charge gives you up to seven hours of continuous play. Charge your Pill almost anywhere, from your Mac’s USB port to any outlet.
Beats by Dr. Dre Pill 2.0 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - active
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
19 cm 4.5 cm
310 g
Hands-Free Function
Enclosure Colour
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth, Near Field Communication (NFC)
Transmission Range
10 m
Controls
Power on/off, volume, call answer, play/pause, next track, previous track
Additional Features
Daisy-chain capability
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Carrying case, AC power adaptor, audio cable, USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
7 hour(s)
19 cm
4.5 cm
310 g
