Beats Flex – All-Day Wireless Earphones – Black
Quicklinx: G05KWS00 Mfr#: MYMC2ZM/A
Connectivity: Wireless
Colours:
26 in stock
£41.66 ex VAT
£49.99 inc VAT
Express delivery Delivered on Tuesday
Flex all day
In your ears or around your neck, Beats Flex are as versatile as the life you lead. Whether you’re listening to music, taking calls or scrolling your social feed, you’ll always be ready for what’s next. Magnetic earbuds make listening that much easier by automatically playing music when they’re in your ears and pausing when they’re attached around your neck¹. The Flex-Form cable provides all-day comfort with durable Nitinol construction, while four ear tip options offer a personalised fit. And when you’re not wearing them, the magnetic earbuds keep Beats Flex tangle-free as they easily coil up into your pocket or bag.
The music stops when you do
Less charging. More flexing. Beats Flex boasts up to 12 hours of listening time for all-day use. If you need a little extra power, 10-minute Fast Fuel charging gives 1.5 hours of playback when battery is low.²
Driven by premium sound
Beats Flex employs a dual-chamber acoustic design and a proprietary layered driver to achieve outstanding stereo separation with rich and precise bass response. Laser cut micro-venting provides ear pressure relief, and the optimised driver angle ensures clear, crisp sound. An advanced digital processor fine-tunes your audio for an accurate and emotive listening experience. The result — rich, powerful sound that keeps you inspired all day long.
Make the connection
Stay connected no matter where your day takes you. With Class 1 Bluetooth® technology, Beats Flex offers extended wireless range and fewer dropouts. An advanced built-in microphone helps reduce wind noise for elevated voice clarity and call performance. On-device controls allow you to adjust volume as well as manage music, take calls or activate voice assistant.
Powered by the Apple W1 chip
The Apple W1 chip seamlessly integrates Beats Flex into your world of Apple products. Simply power on and hold near your iPhone or iPad.³ From there, your Beats Flex are ready to be used with any Apple device that is synced to iCloud so you can seamlessly switch between products, check battery status or share whatever you’re listening to with someone else via Audio Sharing.
Listen with a friend
Audio Sharing lets you wirelessly share audio with Beats Flex and another pair of Beats headphones or AirPods.4 From a song to a podcast or even a film — some things are better together. Now you can easily share whatever you’re listening to on an iPhone, iPad or Apple TV and each control your own volume. Simply bring the second set of compatible Bluetooth headphones near your Apple device and connect with a tap. All that’s left to do is listen — together.
  1. Compatible with iOS and iPadOS 14 or later, macOS 11 or later, watchOS 7 or later, and tvOS 14 or later.
  2. Testing conducted by Apple in August 2020 using pre-production Beats Flex and software paired with iPhone XS Max, 8 Plus and 7 Plus units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50%. Total listening time was up to 12 hours. Testing consisted of full Beats Flex battery discharge while playing audio until Beats Flex stopped playback. 10-Minute charge testing conducted with drained Beats Flex that were charged for 10 minutes, then audio playback was started until Beats Flex stopped playback. Battery life depends on device settings, environment, usage and many other factors.
  3. Requires iCloud account and macOS Sierra, iOS 10, watchOS 3 or later versions.
  4. Audio Sharing is compatible with Beats Flex, Solo Pro, Powerbeats Pro, Powerbeats, Solo3 Wireless, Powerbeats3 Wireless, Beats Studio3 Wireless, BeatsX, AirPods (1st generation or later) and AirPods Pro. Works with iPhone 8 or later and iPod touch (7th generation) with the latest version of iOS; and 12.9-inch iPad Pro (2nd generation or later), 11-inch iPad Pro, 10.5-inch iPad Pro, iPad (5th generation or later), iPad Air (3rd generation) and iPad mini (5th generation) with the latest version of iPadOS.
  • Flex all day
    In your ears or around your neck, these earphones are as versatile as the life you lead. Whether you're listening to music, taking calls, or scrolling your social feed, you'll always be ready for what's next. Magnetic earbuds make listening that much easier by automatically playing music when they're in your ears and pausing when they're attached around your neck. The Flex-Form cable provides all-day comfort with durable Nitinol construction. And when you're not wearing them, the magnetic earbuds keep Beats Flex tangle-free as they easily coil up into your pocket or purse.
  • Driven by premium sound
    Beats Flex employs a dual-chamber acoustic design and a proprietary layered driver to achieve outstanding stereo separation with rich and precise bass response. Laser cut micro-venting provides ear pressure relief, and the optimized driver angle ensures clear, crisp sound. An advanced digital processor fine-tunes your audio for an accurate and emotive listening experience. The result - rich, powerful sound that keeps you inspired all day long.
  • Make the connection
    Stay connected no matter where your day takes you. With Class 1 Bluetooth technology, Beats Flex offers extended wireless range and fewer dropouts. An advanced built-in microphone helps reduce wind noise for elevated voice clarity and call performance. On-device controls allow you to adjust volume as well as manage music, take calls, or activate voice assistant.
  • Powered by the Apple W1 chip
  • Listen with a friend
    Audio Sharing lets you wirelessly share audio with Beats Flex and another pair of Beats headphones or AirPods. From a song, to a podcast, or even a movie - some things are better together. Now you can easily share whatever you're listening to on an iPhone, iPad, or Apple TV and each control your own volume. Simply bring the second set of compatible Bluetooth headphones near your Apple device and connect with a tap. All that's left to do is listen - together.
Beats Flex All-Day - earphones with mic
Earphones - Bluetooth - wireless
Recommended Use
Portable electronics
Additional Functions
Wireless audio sharing
Black beats
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Microphone
On-cable
Controls
Volume, answer/end, voice assistant
1-year warranty
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 2; 4; 5; iPhone 11, 12, 6s, 7, 8, SE, X, XR, XS, XS Max; Mac mini; MacBook Air; MacBook Pro; TV 4K, HD
10.6 cm
86.4 cm
1.6 cm
18.6 g
Black beats
Recommended Use
Protection
Wind protection
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
In-Cord Volume Control
Magnetic ear buds, Apple W1 chip
Microphone
On-cable
Remote Control
Controls
4 pairs of ear tips, USB-C charging cable
Cable Details
USB-C charge cable
Bluetooth Class 1
Auto On/Off
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
12 hour(s)
Limited warranty - 1 year
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Late 2014, Late 2015, Mid 2015, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (7G) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Mid 2017, Mid 2018, Mid 2019) , Apple TV 4K, HD , Apple Watch
Brand: Beats
Stock Status: In stock
