be quiet! SilentWings fans stand for advanced technology, virtually inaudible operation and superior cooling. The third generation of this amazing fan series offers unrivaled and uncompromising performance with a broad range of meticulous optimizations. They feature a smooth-running 6-pole motor, an advanced fluid-dynamic bearing, a unique airflow-optimized fan blade design and a fan frame with funnel-shaped air inlets. The SilentWings 3 120 mm model combines all of the above great features. It strikes the perfect balance between cooling and meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
- be quiet! Silent Wings 3 - case fan
- Product Type
- Case fan
- Package Content
- Screws, Push Pins, silicone washers, adapter cable 12V to 7V, adapter cable 12V to 5V
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 2200 rpm
- Air Flow
- 73.33 cfm
- Noise Level
- 28.6 dBA
- Power Connector
- 3-pin plug
- 12 cm x 12 cm x 2.5 cm
- 137 g
- Anti-vibration
- 3 years warranty
- Product Type
- Case fan
- Package Content
- 12 cm
- 12 cm
- 2.5 cm
- 137 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 2200 rpm
- Air Flow
- 73.33 cfm
- Air Pressure
- 3.37 mm
- Noise Level
- 28.6 dBA
- Power Connector
- 3-pin plug
- Operation Voltage
- 5 - 13.2 V
- Start Voltage
- 4 V
- Rated Current
- 0.37 A
- Power Consumption
- 4.44 W
- Cable Length
- 50 cm
- MTBF
- 300,000 hour(s)
- Anti-vibration
- Limited warranty - 3 years
