Be Quiet Shadow Wings 8cm Mid-Speed Case Fan
Quicklinx: BGWJWS00 Mfr#: BL051
Low-noise operation due to high-quality rifle bearing. The parallel arrangement of recesses on the outer side of the bearing shaft ensure uniform circulation of the high-quality oil and make the fan very quiet. Mechanical noise is minimized by anti-vibration fasteners and the rubberized fan frame. The high-quality IC motor controller reduces electrical noise sources.
  • Long service life
    Reliable cooling for up to 200,000 hours thanks to the high-quality rifle bearing.
  • High air flow
    The flow-optimized surface structure of the fan blades produce more air flow in combination with smooth running.
  • Simple assembly
    Screwless installation makes handling simple.
be quiet! Shadow Wings SW1 Medium Speed - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
2000 rpm
Air Flow
26 cfm
Noise Level
15.8 dBA
Power Connector
3-pin plug
8 cm x 8 cm x 2.5 cm
Anti-vibration
3-year warranty
Case fan
8 cm
8 cm
2.5 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
2000 rpm
Air Flow
26 cfm
Air Pressure
2.25 mm
Noise Level
15.8 dBA
Power Connector
3-pin plug
Operation Voltage
5 - 12 V
Rated Current
0.15 A
Power Consumption
1.8 W
Anti-vibration
TUV S, RoHS, WEEE
Limited warranty: - 3 years
