Fitting everything you want into a HTPC or small form factor PC can be tough, but quietly cooling those cramped components is a far tougher proposition. The ultra-compact Shadow Rock LP premium CPU cooler efficiently and economically solves this special problem.
If you are seeking the best possible mix of premium cooling performance for restricted space situations, remarkably quiet operations, eye-catching design, and a highly attractive price in the compact CPU cooler segment, seek no further. Shadow Rock LP is the cooler for you.
- be quiet! Shadow Rock LP - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA1155 Socket, LGA1150 Socket, LGA1151 Socket, LGA2011 (Square ILM) Socket, Socket AM4, LGA1200 Socket, LGA1700 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 87 cfm
- Noise Level
- 14.8/18.6/25.5 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm), TDP up to 130W
- 13.4 cm x 12.2 cm x 7.54 cm
- 390 g
- Up to 130W Thermal Design Power (TDP)
- 3-year warranty
- Product Type
- Processor cooler
- 13.4 cm
- 12.2 cm
- 7.54 cm
- 390 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Heatsink Dimensions
- 134 mm x 122 mm x 50.4 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 87 cfm
- Air Pressure
- 1.25 mm
- Noise Level
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.09 A
- Power Consumption
- 1.1 W
- Cable Length
- 22 cm
- Mounting Kit
- Included
- MTBF
- 80,000 hour(s)
- Limited warranty: - 3 years
