Be Quiet Pure Base 600 2 Fans ATX Gaming Case - Black/Silver
Quicklinx: CNH5WS00 Mfr#: BG022
Pure Base 600 is truly multi-talented, offering a great deal of functionality and features for an attractive price. This case sets new standards in its performance class with high installation flexibility and effective cooling performance. Smart usability features and whisper-quiet operation enable you to realize almost any system configuration you desire for your ATX or micro ATX PC. It's simply the perfect base to build your system on.
be quiet! Pure Base 600 - tower - ATX
System cabinet
Tower
Silver
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Removable dust filter, front dust filter, supports 120 mm radiator in rear, side panel sound-damping foam mats, removable HDD cage, bottom dust filter, supports 120/140/240/280/360 mm radiator in front panel, supports 120/240/360 mm radiator in top, top panel sound-damping foam mats, front panel sound-damping foam mats, manual fan speed control (3 channel)
No power supply (ATX / PS/2)
22 cm x 49.2 cm x 47 cm
7.44 kg
3-year warranty
Tower
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
2
Product Material
Steel, ABS plastic
Silver
Cooling System
Front: 140 x 140 x 25 mm fan x 1 / 900 rpm / 55.8 cfm / 17.1 dBA / 1 x 120/140 mm fan supported , Rear: 120 x 120 x 25 mm fan x 1 / 1200 rpm / 41.7 cfm / 16.8 dBA / Pure Wing 2 , Top: 140 mm fan mount x 2 / 2 x 140 mm fan or 3 x 120 mm fan supported
CPU Cooler Max Height
165 mm
Video Card Max Length
425 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 2 x 2.5"/3.5" shared
Expansion Slots
7
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
Cable ties, screws
No power supply
Specification Compliance
ATX / PS/2
22 cm
49.2 cm
47 cm
7.44 kg
Limited warranty - 3 years
