Outstanding flexibility and silence
be quiet! Dark Base Pro 900 Silver is the perfect case for all of those who expect the highest standards when it comes to modularity, compatibility and design.
- Relocatable motherboard tray with the possibility of an inverse layout
- Repositionable HDD tray with single HDD slots for individual space requirements
- Three virtually inaudible be quiet! SilentWings® 3 140mm PWM fans
- Advanced PWM hub and manual fan controller supports up to four PWM and four 3-pin fans
- Full-circuit airflow system with noise-reducing vents all around the case
- Ready for radiators up to 420mm on top, front, back and base
- Completely sound insulated with decoupled motherboard, PSU and drives
- Fully windowed side panel from tinted and tempered glass
- Eye-catching, freely positionable LED illumination
- Wireless charger for Qi enabled devices (e.g. smart phones)
- Three years manufacturer’s warranty
- German product conception, design and quality control
- be quiet! Dark Base Pro 900 - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Silver
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ATX, Extended ATX, XL-ATX
- System Cabinet Features
- Screwless drive bays, side panel dust filter, removable dust filter, vibration damping, front dust filter, water cooling holes, cable management system, removable HDD cage, bottom dust filter, airflow channels, integrated Qi (wireless charging dock), RGB illumination
- Power Device
- No power supply
- 24.3 cm x 57.7 cm x 58.5 cm
- 14.39 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 2
- Product Material
- Aluminium, steel, ABS plastic
- Silver
- Cooling System
- Front: 140 x 140 x 25 mm fan x 2 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Rear: 140 x 140 x 25 mm fan x 1 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Front: 120/140 mm fan mount x 1 , Top: 120/140/180 mm fan mount x 4 / 4 x 120 mm or 3 x 140 mm or 1 x 180 mm fan supported , Bottom: 120/140 mm fan mount x 2
- CPU Cooler Max Height
- 185 mm
- Video Card Max Length
- 470 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x internal - 2.5" , 7 (total) / 7 (free) x internal - 3.5"
- Expansion Slots
- 8
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
- PWM hub
- RoHS 2011/65/EU
- Power Device
- No power supply
- 24.3 cm
- 57.7 cm
- 58.5 cm
- 14.39 kg
- Limited warranty - 3 years
