Outstanding flexibility and silence
be quiet! Dark Base 900 Silver is the perfect case for all of those who expect the highest standards when it comes to modularity, compatibility and design.
- Relocatable motherboard tray with the possibility of an inverse layout
- Repositionable HDD tray with single HDD slots for individual space requirements
- Three pre-installed, virtually inaudible be quiet! SilentWings® 3 140mm PWM fans
- Manual stepless fan controller supports up to three PWM and three 3-pin fans
- Effective full-circuit airflow system with noise-reducing vents all around the case
- Water cooling ready for radiators up to 420mm on top, front, back and base
- Completely sound insulated with decoupled elements for motherboard, power supply and drive slots
- Three years manufacturer’s warranty
- German product conception, design and quality control
be quiet! Dark Base 900 Silver offers unrivaled flexibility with impeccable cooling and silence features. Simply an engineering work of art!
- be quiet! Dark Base 900 - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Silver
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ATX, Extended ATX, XL-ATX
- System Cabinet Features
- Screwless drive bays, side panel dust filter, removable dust filter, vibration damping, front dust filter, water cooling holes, cable management system, removable HDD cage, bottom dust filter, airflow channels
- Power Device
- No power supply
- 24.3 cm x 57.7 cm x 58.5 cm
- 14.18 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 2
- Product Material
- Aluminium, steel, ABS plastic
- Silver
- Cooling System
- Front: 140 x 140 x 25 mm fan x 2 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Rear: 140 x 140 x 25 mm fan x 1 / 1000 rpm / 59.5 cfm / 15.5 dBA / SilentWings 3 , Front: 120/140 mm fan mount x 1 , Top: 120/140/180 mm fan mount x 4 / 4 x 120 mm or 3 x 140 mm or 1 x 180 mm fan supported , Bottom: 120/140 mm fan mount x 2 , Side: 120 mm fan mount x 2
- CPU Cooler Max Height
- 185 mm
- Video Card Max Length
- 470 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x internal - 2.5" , 7 (total) / 7 (free) x internal - 3.5"
- Expansion Slots
- 8
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS 2011/65/EU
- Power Device
- No power supply
- 24.3 cm
- 57.7 cm
- 58.5 cm
- 14.18 kg
- Limited warranty - 3 years
