Exceptionally Quiet, Superior Reliability, Great Value
Whether you’re assembling a very quiet system, upgrading an existing PC, or building a multi-GPU gaming system, your build will benefit from this PSU that simply has the best combination of features at a very popular prize.
- Two 12V-rails and up to four PCI-express connectors for powerful multi-GPU systems
- 80PLUS ® Silver certification and up to 91% power conversion efficiency
- Exceptionally quiet operation thanks to use of a silence-optimized 120mm be quiet! fan
- Stable operation thanks to DC-to-DC power conversion technology
- Modular cable management simplifies component installation and reduces annoying clutter
- Fixed 24-pin and P8 cables with high-quality single layer sleeve
- Easy-to-use flat drives and PCIe cables offer more space for installation
- Top component protection with full suite of safety features
- Meets latest Intel ® C6/C7, ErP and Energy Star guidelines
- 3-year manufacturer’s warranty
- Product conception, design and quality control in Germany
- be quiet! Pure Power 10 CM - power supply - 700 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Silver
- 2.16 kg
- Localisation
- English, German, French, Polish, Russian, Spanish
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- +3.3V - 25 A , +5V - 20 A , +12V1 - 36 A , +12V2 - 30 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties
- Black
- 15 cm x 16 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- PSU Form Factor
- ATX
- Black
- Localisation
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- Efficiency
- 90.9% at 20% Load, 91.9% at 50% Load, 91.3% at 100% Load
- Power Factor (PF)
- 0.99
- 80 PLUS Silver
- Cable ties
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, active CLAMP circuitry, DC-DC technology, Synchronous Rectifier (SR) technology, semi-modular
- TUV, BSMI, DEMKO, FIMKO, NEMKO, SEMKO, CB, FCC, RoHS, WEEE, cTUVus, ERP, RCM, cRUus, CU
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years
- 40 °C
- 15 cm
- 16 cm
- 8.6 cm
- 2.16 kg
- Shipping Width
- 26 cm
- Shipping Depth
- 20.2 cm
- Shipping Height
- 9.8 cm
- Shipping Weight
- 2.59 kg
