Be quiet! Straight Power 10 700W CM provides a new level of silent performance for systems that demand whisper-quiet operation without facing the slightest compromise in power quality. Special German team has updated and designed even more premium features into this generation of the Straight Power series, which make the Straight Power 10 700W CM more silent than ever and a clear 'Best Choice' for new systems and as a replacement in existing systems.
- be quiet! Straight Power 10 700W CM - power supply - 700 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 2.57 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V1 - 18 A , +12V2 - 18 A , +12V3 - 22 A , +12V4 - 22 A , -12V - 0.5 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 11 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties, thumbscrews
- Black
- 15 cm x 16 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 5-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- Efficiency
- 93%
- 80 PLUS Gold
- Cables Included
- Power cable - external - 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, Multi-GPU Technologies Supported, 4 x 12V rail, CrossFireX ready, thermal protection, fluid dynamic bearing cooling fan
- TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, ERP
Sustainability Information
- ENERGY STAR
- Limited warranty - 5 years
- 40 °C
- Sound Emission
- 10.5 dBA
- 15 cm
- 16 cm
- 8.6 cm
- 2.57 kg
- Shipping Width
- 24.8 cm
- Shipping Depth
- 32.8 cm
- Shipping Height
- 10.2 cm
- Shipping Weight
- 3.15 kg
