Be Quiet BN227 SFX POWER 2 Power Supply 400 Watts
Quicklinx: B1B5WS00 Mfr#: BN227
The high-power SFX Power 2 400W compact PSU gives you more for your mini or media PC. Its design supports the technologies and efficiency standards, while providing solid voltages and enough power to support a discrete PCIe graphics card.
For compact PC systems that perform well beyond the ordinary, with a great combination of quietness, features, reliability and efficiency, choose SFX Power 2 400W.
be quiet! SFX Power 2 400W - power supply - 400 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
SFX12V 3.3
80 PLUS Certification
80 PLUS Bronze
0.95 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
400 Watt
Output Current
+3.3V - 21 A , +5V - 22 A , +12V1 - 17 A , +12V2 - 16 A , -12V - 0.5 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 4 x 15 pin Serial ATA power
Cooling System
80 mm fan
Cable ties
12.5 cm x 10 cm x 6.35 cm
Environmental Standards
ENERGY STAR
SFX12V 3.3
PSU Form Factor
SFX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
400 Watt
Output Current
Efficiency
89%
80 PLUS Bronze
Cable ties
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
80 mm fan
Over current protection, over voltage protection, overload protection, undervoltage protection, dual 12V rails, short-circuit protection, non-modular
TUV, CB, RoHS, WEEE, ERP
Sustainability Information
ENERGY STAR
10 °C
50 °C
Sound Emission
33.9 dBA
12.5 cm
10 cm
6.35 cm
0.95 kg
Shipping Width
19.9 cm
Shipping Depth
19.5 cm
Shipping Height
7.5 cm
Shipping Weight
1.3 kg
