Be Quiet BL044 Pure Wings 2 8cm Case Fan Rifle Bearing Black
Quicklinx: B1D1WS00 Mfr#: BL044
Type: Case Fan
£7.09 ex VAT
£8.50 inc VAT
The Pure Wings 2 family fans are unique in their class, combining outstanding reliability, silent cooling, and a great price-for-performance ratio. It is impressive how much quiet technology the engineering team has crammed into these fans at this amazing price. They are the ultimate reason to put well-known be quiet! silent cooling in your PC if you haven't already done so.
The Pure Wings 2 80 mm model combines all of the above essential features. It provides maximum cooling airflow and operating noise levels down to a silent 18.2 dB. The increased air pressure makes the fans especially recommended for use in air cooling setups.
be quiet! Pure Wings 2 - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1900 rpm
Air Flow
26.3 cfm
Noise Level
18.2 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
8 cm x 8 cm x 2.5 cm
3-year warranty
Case fan
8 cm
8 cm
2.5 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1900 rpm
Air Flow
26.3 cfm
Air Pressure
1.85 mm
Noise Level
18.2 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Operation Voltage
5 - 12 V
Start Voltage
5 V
Rated Current
0.11 A
Power Consumption
1.57 W
Cable Length
46 cm
Mounting Kit
Included
MTBF
80,000 hour(s)
UL, TUV
Limited warranty: - 3 years
Type: Case Fan
Brand: Be Quiet
