Dark Rock CPU coolers have long been category leaders, and now the significantly upgraded Dark Rock 3 is even more powerful. This virtually inaudible single-tower CPU cooler puts famous be quiet! SilentWings technology in your PC where it really counts. They are excellent for overclocked systems and demanding multi-graphics platforms.
Dark Rock 3 offers top performance-to-noise ratio and the highest reliability available. Improved cooling efficiency and really silent operation mean this cooler strikes the perfect balance between cooling and serenity - truly silence and performance without compromises.
- be quiet! Dark Rock 3 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Dark nickel
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Aluminum with nickel plated copper base
- Fan Diameter
- 135 mm
- Fan Height
- 22 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 67.8-113.8 cfm
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- 6 heatpipes (6 mm)
- 13.7 cm x 9.7 cm x 16 cm
- 976 g
- Nickel plated, Silent Wings
- Localisation
- English, German, French, Polish, Spanish
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 13.7 cm
- 9.7 cm
- 16 cm
- 976 g
- Dark nickel
- Localisation
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fan Diameter
- 135 mm
- Fan Height
- 22 mm
- Fan Bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 67.8-113.8 cfm
- Air Pressure
- 2.1 mm
- Noise & Performance Details
- 8.4 dBA at 700 rpm , 13.6 dBA at 1050 rpm , 21.1 dBA at 1400 rpm
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 1.11 A
- Power Consumption
- 1.56 W
- Mounting Kit
- Included
