Be Quiet BK013 Shadow Rock 2 CPU Cooler
Quicklinx: B1CQWS00 Mfr#: BK013
Type: CPU Cooler
Stock Status: Clearance
Hurry, only 1 left in stock!
£29.12 ex VAT
£34.94 inc VAT
Express delivery Order within the next 9 hours for delivery on Monday
Shadow Rock 2 is a top choice among premium CPU coolers, with exceptionally high performance, well-known be quiet! Low noise operations and a category-beating price. If you are seeking the best possible mix of exceptionally high cooling performance, remarkably quiet operations, and highly attractive price in the premium CPU cooler segment, your search is over. Shadow Rock 2 simply has to be your choice.
be quiet! SHADOW ROCK 2 processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1600 rpm
Air Flow
51 cfm
Noise Level
15.3/19.8 /25.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
12.2 cm x 14.7 cm x 16 cm
1.12 kg
3-year warranty
Processor cooler
Package Content
Thermal paste
12.2 cm
14.7 cm
16 cm
1.12 kg
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
160 mm x 122 mm x 122 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1600 rpm
Air Flow
51 cfm
Air Pressure
1.4 mm
Noise Level
15.3/19.8 /25.4 dBA
Noise & Performance Details
15.3 dBA at 900 rpm , 19.8 dBA at 1250 rpm , 25.4 dBA at 1600 rpm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.24 A
Cable Length
22 cm
Mounting Kit
Included
Limited warranty - 3 years
Type: CPU Cooler
Brand: Be Quiet
Price Range Ex VAT: 0 - 50
