The decoupled 135 mm Shadow Wing's PWM fan ensures a perfect mix of cooling power and noise production. The waveshaped contour on the cooling fins minimizes noise and optimizes the air flow.
Four 8 mm heatpipes transport the heat along the shortest path to the optimal point within the cooling fins. The TopFlow cooler-layout enables ideal cooling not only for the CPU but also for surrounding components.
Extra quiet operation through be quiet
The decoupled 135 mm Shadow Wing's PWM fan ensures a perfect mix of cooling power and noise production. The waveshaped contour on the cooling fins minimizes noise and optimizes the air flow. -
Very high cooling efficiency
Four 8 mm heatpipes transport the heat along the shortest path to the optimal point within the cooling fins. The TOPFLOW cooler-layout enables ideal cooling not only for the CPU but also for surrounding components. -
Space-saving mounting
Perfect for use in desktop housing thanks to the low height of the cooler. -
High-quality materials
Complete nickel-plated cooling element. Stable backplate for a shock-proof sit, even when the computer is being transported.
- be quiet! Shadow Rock TOPFLOW SR1 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
- Heatsink Material
- Nickel plated aluminum
- Fan Diameter
- 135 mm
- Fan Height
- 25 mm
- Rotation Speed
- 900-1500 rpm
- Air Flow
- 66.8 cfm
- Power Connector
- 4-pin fan connector
- Pulse-width modulation (PWM) support, 4 copper heatpipes
- 13.7 cm x 17 cm x 12.5 cm
- 0.65 kg
- Anti-vibration
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 13.7 cm
- 17 cm
- 12.5 cm
- 0.65 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fan Diameter
- 135 mm
- Fan Height
- 25 mm
- Rotation Speed
- 900-1500 rpm
- Air Flow
- 66.8 cfm
- Air Pressure
- 2.1 mm
- Noise & Performance Details
- 9.6 dBA at 900 rpm , 15.9 dBA at 1200 rpm , 24.4 dBA at 1500 rpm
- Power Connector
- Rated Current
- 0.22 A
- Mounting Kit
- Included
- Anti-vibration
- RoHS, WEEE
- Limited warranty: - 3 years
